Model Builder Request Failed. Problem 210, Model Builder Not Working!
hydroplan
Message 1 of 32
hydroplan
Hello There, Absolute beginner with infraworks here so be patient.
I'm attempting to use model builder for a select area that comes under the 200 sq.km limit. However when i select create model, i get the error code 210. I've looked at several forums and attempted to find a solution myself. However to no avail. I'm just looking for some advice or a solution to this problem,
Many thanks,
Rob
Replies (31)
Message 21 of 32
brad_witt
I am also getting that same error. I was able to create the model yesterday, but when I tried exporting it, it was taking forever so I thought it may be corrupt or something so I deleted it and was going to try again and now getting the error.
Message 22 of 32
SethHall
@brad_witt
Is this with all models or just one? Can you try creating a new one and let me know if it is successful?
Seth Hall
Product Owner
Model Builder
Message 23 of 32
brad_witt
When I try to create a new one that is when I get the error
Message 24 of 32
SethHall
@brad_witt
Can you try logging out of InfraWorks and back in again?
Also what version are you using?
Seth Hall
Product Owner
Model Builder
Message 25 of 32
brad_witt
@SethHall I tried that and still same issue. I believe I am using 2020
Message 26 of 32
SethHall
@brad_witt  check your private messages
Seth Hall
Product Owner
Model Builder
Message 27 of 32
brian.babu
@SethHall
I've also tried all the steps indicated here in the forum but still can't extract a map from the model builder
Message 28 of 32
SethHall
@brian.babu Same issue (error 210) or something different?
If different, please let me know let me know the issue. The more details the better. Thanks
Seth Hall
Product Owner
Model Builder
Message 29 of 32
brian.babu
@SethHall  Log to the problem. Kindly Assist
Message 30 of 32
SethHall
@brian.babu The logs state that there is a network issue. What is the error message you are receiving in Model Builder?
Also do you have any proxy server? Check this knowledge base article: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Seth Hall
Product Owner
Model Builder
Message 31 of 32
SethHall
@brian.babu Is Model Builder now working for you or are you still having issues?
Seth Hall
Product Owner
Model Builder
Message 32 of 32
brian.babu
@SethHall Yes, I was finally successful in loading the model without issues though some buildings are picked as mounds. Thanks you for the assistance.
