InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Model builder not working??
19 REPLIES 19
Message 1 of 20
Matt__W
4810 Views, 19 Replies
Is there an issue with the Model Builder service? I know the Health Dashboard shows InfraWorks as "Currently working as expected" but I tried creating a model about 30 minutes ago and it's still not showing up. And just to make sure I wasn't losing my mind, I tried to create another model and still nothing. It's never taken longer than a couple of minutes for it to show up in InfraWorks.
https://health.autodesk.com/
Anyone??
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
19 REPLIES 19
Message 2 of 20
JasonArtley
in reply to: Matt__W
The Model Builder selection process worked as normal, but the model has yet to show up. It's been 10 minutes, when it usually takes 1.
I'm still on 18.1.36.0, but that might not be a factor.
Message 3 of 20
Matt__W
in reply to: JasonArtley
I tried using both my work account and my Expert Elite account (on a separate machine). Both have yet to create a model. Also, both machines are running 18.2.50.0 so not sure if that has anything to do with it. Hmmmm.... Kinda dead in the water at the moment.
Matt Wunch
Twitter | LinkedIn
Message 4 of 20
elliott.rosenfeld
Hey Matt,
I asked the Dev team to look into it. I'll let you if we find any issues with the Model Builder service. Do you happen to have the ID # for your Model Builder attempts today?
Elliott
Principal Specialist, Infrastructure
Message 5 of 20
Matt__W
in reply to: elliott.rosenfeld
I thought about that AFTER I clicked the closed button. And since I haven't received any emails I don't have the IDs. Are they tucked away in a LOG file somewhere perhaps?? Or can you look it up based on log in account name/email?
Matt Wunch
Twitter | LinkedIn
Message 6 of 20
Matt__W
I just created a new model of the exact same area (to get you a tracking ID#) and it went right through. Showed up almost instantly for my Expert Elite account. Same with my work account. So I guess it's working now??
Still haven't seen the previous models show up though.
Matt Wunch
Twitter | LinkedIn
Message 7 of 20
SethHall
Hi @Matt__W
It looks like there was an issue with model requests timing out for a couple hours this morning (EST), thank you for confirming it is working now. Please let us know if you run into any further issues.
Thanks again!
Seth Hall
Product Owner
Model Builder
Message 8 of 20
Matt__W
Speaking of the tracking ID#... why is that not included in the emails anymore?
Matt Wunch
Twitter | LinkedIn
Message 9 of 20
JasonArtley
I just tested mine as well and it's working as it should.
Message 10 of 20
SethHall
Hi @Matt__W
The tracking ID has been removed from the emails, as it represented little use for end users.
Thanks again for reporting the issue, and confirming everything is working!
Seth Hall
Product Owner
Model Builder
Message 11 of 20
Model builder crashes my computer immediately upon selecting it.  I have tried uninstalling and re-installing.  I have deleted adware programs and updated my graphics driver.  It still crashes.
Message 12 of 20
Karsten.Saenger
Hi @Anonymous,
can you send the InfraWorks log files from C:\Users\<<USER>>\AppData\Roaming\Autodesk\Autodesk InfraWorks\logs ?
Do you have the chance to submit a CER report when the program crashes? If yes, please enter your email address and submit it, if a CER number is displayed, please send the number.
Karstren.
Karsten Saenger
Message 13 of 20
in reply to: SethHall
I am having the same issue.  I have attached my screen shot showing the ID. I have tried to close out and log back in. I do have limited space on my Cdrive is this causing the issue? I have about 7GB remaining.
Message 14 of 20
SethHall
Hi @Anonymous
How long ago did you make the Model request? Which version are you using?
Seth Hall
Product Owner
Model Builder
Message 15 of 20
Thank you for your quick response.
Time I created was 11:05am MST. I have created multiple ones all morning, starting at 8:00am and nothing has shown up yet.
I am using 18.2.50.0 version
Message 16 of 20
SethHall
Hi @Anonymous
I am looking into it right now... I'll let you know what I can find out. Let me know if any of your Models come back in the meantime.
Thanks!
Seth Hall
Product Owner
Model Builder
Message 17 of 20
mbelleza
I am having the same issue here. Is it related to the service changes happening today?
Message 18 of 20
SethHall
in reply to: mbelleza
Hi @Anonymous & @mbelleza
Please follow this thread as I will be providing updates for the status of this issue here: https://forums.autodesk.com/t5/infraworks-forum/monday-04-09-2018-model-builder-experincing-issues/td-p/7918851
Thanks for reporting!
Seth Hall
Product Owner
Model Builder
Message 19 of 20
Can I still use model builder if my license expired?..  many time trying, still failed.. and nothing appear..
Message 20 of 20
Karsten.Saenger
Hi @Anonymous ,
without an active InfraWorks subscription you should not even be able to open a "normal" InfraWorks and create new (Model Builder) models, but only Infraworks in Viewer Mode.
Karsten.
Karsten Saenger
Rail Community
