Material begins at each point instead of being continuous
ivan7890
ivan7890
Hi, I have created a fence material which I have applied to an sdf alignment. The material begins at each polyline point instead of being continuous, whats the best way to fix this?
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @ivan7890
I cannot recreate the issue on my system.
I have created a polyline in Civil 3D and added vertices on the straight line.
Then exported to SDF and imported to InfraWorks, result is:
Is your polyline straight or are there corners at the vertex points?
Karsten.
Karsten Saenger
Is that one continuous polyline, or is it several polylines all end to end?
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous
it's one continuous polyline in my case.
Karsten.
Karsten Saenger
ivan7890
Hi, it is one continuous polyline in civil3d. It was given to me by the civil designers and exports as a single line with multiple vertices. I believe the way the line was generated was a drape over a surface.
I have had to manually draw a barrier using the imported as a reference.
Just from having another look at your picture, it looks like all of the vertices are at different elevations, its possible that this could be the reason.
