JAVASCRIPT documentation
I am getting a bit frustrated to find any API documentation that explain how to use Infraworks functioncs / calls available withing the scripting tool.
Any idea where I can find anything? This should be part of the software documentation...
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
the Java Script API is not supported, but you can find information in the Autodesk Knowledge Base:
http://knowledge.autodesk.com/article/Autodesk-InfraWorks-JavaScript-API-Documentation
Karsten.
Karsten Saenger
Yes but the zip file in that pages seems corrupted or I can't manage to extract myself for some strange reason
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
I just tested the zip file of the article and it worked fine for me. I used the free "7-zip" program to extract it.
I have attached another zip file with the "standard" extension, can you extract that?
Karsten.
Karsten Saenger
it worked thanks
