Design Parametric bridge component in revit for infrawork, what are the possi ?
Hi, please, Is it possible to create parametric bridge components within revit for use in infrawork, as we can do with inventor!?
Tomislav.Golubovic
Not utilising Inventor, you could always use Dynamo to 'drive' the Revit model, but you'll have to use the Revit file, or export to another 3D file format to use in InfraWorks.
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
the direction Revit to InfraWorks with intelligent objects is not supported (yet).
If you open a Revit file in InfraWorks it's a 3D model.
You can send InfraWorks bridges to Revit, but not vice versa, see InfraWorks Help: To send a bridge to Autodesk Revit
Karsten.
Karsten Saenger
Ok,Thanks you .
Ok, I see.
Thanks.
