Infraworks model to Client
neilyj666
Mentor Mentor
neilyj666
I was on  Teams call with a potential client yesterday and I was sharing my screen where I demonstrated our Infraworks model of the proposed project and they were keen to get the model as they have just got Infraworks apparently. I would normally just use Shared views or export the model as an fbx for third parties to view in Navisworks Freedom.
Do I just need to send the .sqlite file or what files would I need to supply for them to be able to open the model - it has many data sources from GIS data, Civil 3D drawings, 3D models etc from various folders so would all this information be preserved?
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @neilyj666 ,
to share a complete InfraWorks model, you can either upload it to Bim360 and share the Bim360 folder with another user. He shoukld then be able to download the model from his InfraWorks start screen.
Or, create a zip file of your model.sqlite and model.files folder and share that zip file.
The modle can be opened on any other computer in both cases. But if you want to edit or change any existing data source, you need to have the original data source available. It's possible to reconnect to them if paths have changed.
Karsten.
Karsten Saenger
neilyj666
Hi @Karsten.Saenger thanks for the reply
I don't have BIM 360 so the zip method sounds the best option for this
