Infraworks Design Surface Buried
SUHI121
Observer Observer
SUHI121
Observer
Observer
I imported the ground and design surface to Infraworks. Grey-coloured surface is the design surface which i want it on the top. But it is covered with the existing ground surface in the cut regions. If change the design surface as ground surface its coming fine but the imagery is also coming onto the ground surface, which I don't want. What to do?
Todd_Rogers
Can you not just turn the imagery off?
Todd Rogers
Civil Administration
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @SUHI121 ,
images in InfraWorks are draped on ground surfaces only. Any other surface layer can only be displayed with a color.
Have you tried moving the design surface above the existing surface in the ground surface layer?
Karsten.
Karsten Saenger
