InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Infraworks 360 Terrain Data Source
16 REPLIES 16
Message 1 of 17
izzybabur
4540 Views, 16 Replies
Does anyone know what the source data is for Infraworks 360? I'm using NASA SRTM 90 for my surface in Civil 3D and running some preliminary designs based on that surface. However, when I bring in my corridor model into IW360, the elevations don't line up and are quite off.
Should I import my surface too? It's quite a massive surface though, and I'm afraid I would lose all the other infrastructure and terrain data by bringing in the SRTM 90 surface.
Any suggestions or help would be appreciated!
izzy
16 REPLIES 16
Message 2 of 17
If you use the Model Builder to create a model, these are the data sources:
  • Terrain: Terrain data for the United States and its territories uses USGS 10 and 30 meter DEMs from the National Elevation Dataset (NED). Between -60° and +60° latitude we use SRTMGL1 30m DEM data. Between +60° and +83° latitude we use ASTER GDEM v2 30m DEM data.
  • Roads: OpenStreetMap's Highway and Railway datasets are readily available. They will be used to create roads and railway features in the model.
  • Buildings: Building data is from the OpenStreetMap dataset.
  • Imagery: Satellite imagery from Microsoft® Bing Maps is draped over the model terrain.
Elliott
Principal Specialist, Infrastructure
Message 3 of 17
Hi @elliott.rosenfeld
Thanks for your response - I appreciate it! That really helps to clarify and answer a few further questions I had.
So if I was using 1 Arc Second data in Civil 3D instead of the SRTM 90 data, it would theoretically line up perfectly when I bring it into Infraworks 360 (for areas within +/- 60° latitudes) correct?
Thanks again,
izzy
Message 4 of 17
roskirko
in reply to: izzybabur
At the equator, 1 Arc Second is over 30 m (30.87m). Alignment can be perfect. The resolution in the CONUS is down to 10 m, I believe (i.e. better resolution than 1 Arc Second).
Geographic Information Systems
Fanshawe College
Message 5 of 17
in reply to: elliott.rosenfeld
Thank you @elliott.rosenfeld for the detailed explination of data source within the US.
I have not used the program but currently looking into using InfraWorks in my workflow.
What about the data source for Europe/Asia?
Message 6 of 17
Karsten.Saenger
Hi @Anonymous
I believe for most regions in Europe you get SRTM data out of the model builder.
Depending on what region you are looking for, it'S definitely worth to search the internet for official free datasets. For example, Austria offers a free 10m resoltution LIDAR terrain dataset for the whole country.
I know of other countries and regional authorities that offer similar datasets, i.e. Alto Adige in Northern Italy.
Karsten
Karsten Saenger
Message 7 of 17
in reply to: Karsten.Saenger
Thank you @Karsten.Saenger.
Specificaly do you know what data is available for Germany?
Message 8 of 17
Karsten.Saenger
Hi @Anonymous
the German authorities want you to pay for LIDAR terrain data, I am not aware of any free data other than the SRTM's.
Sometimes, if you have luck, you can find local authorities WMS server with (mostly) aerial imagery, but sometimes also terrain is included. But even then, bringing in WMS data into InfraWorks is not ideal.
Karsten.
Karsten Saenger
Message 9 of 17
What about Data sources for other countries that are not US?
Message 10 of 17
Elliott
Message 11 of 17
Karsten.Saenger
Hi @Anonymous
the same rules apply for the model builder: SRTM elevation data and free OpenStreetMap data worldwide.
Karsten
Karsten Saenger
Message 12 of 17
Non-US data for Asian version. Where can we sourced this terrain data?
Message 13 of 17
mconway
Can you tell me the date of the most current Elevation Data used by Infraworks? in the SE Pennsylvania Area, please.
At your service,
__________________________________________________
Mark A Conway –Director of Design Technology | Gilmore & Associates, Inc.
Autodesk Certified Instructor
AutoCAD Civil 3D Certified Professional
Autodesk Certified BIM Specialist for Roads and Highways
Message 14 of 17
Karsten.Saenger
in reply to: mconway
Hi @mconway ,
please have a look at the data source information in the Model Builder:
The exact dates of the elevation data can be found on the according USGS sites.
Karsten.
Karsten Saenger
Message 15 of 17
mconway
Thanks, Karen. Got it!! Dec 31, 2014
At your service,
Message 16 of 17
sduffin
Elliot - has the source of data changed from your original answer back in 2017?  Is Autodesk considering utilizing any other default data sources for the model builder?  Thanks!
Message 17 of 17
What about terrain data sources for Asia such as Malaysia?
Rail Community
