InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
InfraWorks 2015.3 slow while browsing folders
4 REPLIES 4
797 Views, 4 Replies
Browsing in folders is very, very slow by browsing for adding data sources also by defining location for model builder data.
Please, let me know a solution.
Greetings,
Gerard
Greetings,
Gerard
4 REPLIES 4
Karsten.Saenger
Karsten.Saenger
Autodesk Support
Autodesk Support
in order to share the solution in this issue:
The issue was solved by turning off "use system proxy settings" in the application options.
Karsten.
Karsten Saenger
Karsten.
Karsten Saenger
sara.makarenko
Hi. Is anyone else experiencing this issue? Please let me know if you are.
Sara Makarenko
InfraWorks 360 User Experience Designer
Sara Makarenko
User Experience
Sara Makarenko
Sara Makarenko
User Experience
John_DeLeeuw
Hi Sara and Gerard,
Can this Registry Edit help out with the problem? --> Login to Autodesk InfraWorks 360 does not work when using a Proxy Server
I've also noticed very slow browsing of folder structures but only when I have a very huge and detailed model in InfraWorks and want to export out a video sequence on full quality. Then it's very slow to choose the destination folder on even a local drive. Example of this 'huge' model --> Wilhelminapier Rotterdam
John
@Gerard: misschien een idee om jezelf in te schrijven voor een InfraWorks workshop? Vrijdag 13 februari in Oosterhout. Inschrijven kan hier
John de Leeuw
Senior Consultant
Community Ambassador - Twitter - LinkedIn
Hi Sara and Gerard,
John
John de Leeuw
Senior Consultant
in reply to: John_DeLeeuw
Hi John,
The registry setting Use_Proxy=true was the problem. The solution is to change the setting to Use_Proxy=false.
I don't experience slow browsing by using huge models.
By the way, nice IW-model of Rotterdam!
Gerard
Hi John,
Gerard
Rail Community
