InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
IMPORTED ROADS FROM CIVIL 3D TO INFRAWORKS NOT GETTING DRAPPED
4 REPLIES 4
oliverkisera
244 Views, 4 Replies
oliverkisera
Hello good people, i started off my design in civil 3D by creating a surface from topo points, then created an alignment , now when importing into infraworks, the surface looks okay but when I import the alignment, it digs the surface and doesnt look right, ive tried enabling the drape feature but it still digs the surface, ive attached a screenshot, kindly help me solve this, thanks in advance
4 REPLIES 4
Matheus-Lima
in reply to: oliverkisera
Matheus-Lima
Hi @oliverkisera, how are you?
Well, did you try to change the assembly? Is it a four-lane road? It seems that some stations are outside the surface. Perhaps, if you could import the surface with a bigger offset from your alignment would avoid this "border effect".
Cheers,
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Cheers,
Matheus Lima
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @oliverkisera ,
I think @Matheus-Lima is right. It looks like the road is too wide for your surface. It's connecting to elevation 0.0 where no surface exists.
Make the surface larger in Civil 3D to give more space in InfraWorks.
Karsten.
Karsten Saenger
Hi @oliverkisera ,
Karsten.
Karsten Saenger
oliverkisera
in reply to: Matheus-Lima
oliverkisera
youre 100% right, you saved my day, thanks for your quick response and I apologize for acknowledging late that your response solved my problem, Ive learnt something new and thanks again!!!!
Matheus-Lima
Matheus-Lima
Yes!! Glad to help, in case of more doubts we're here 😁
Matheus Lima
Matheus Lima
Rail Community
