import sdf as barrier for fence/guard rail extends beyond vertices
Riyaz.Hussain
Riyaz.Hussain
I am importing polygon or lines in infraworks to create fence - but it extends beyond the vertices.
Please provide the solution.
Infraworks 2020
georg.grebenyuk
Good day, I have similar situation in all Cases with cutting model (using boarders in Model's property - draw or select polygon) or importing another contours (sdf, shp ...) - and I must delete points in object that goes farher that surface.
I think - it's global problem of IW (because IW can't add to object's geometry new point (as f.e. work "broader" = structural line in Civil 3D's Surfaces))
Other visible problem - when boarder going through building - and it was no cut.
May be there is command to Java - delete parts of problems objects automatically...
Best regards,
Egor Grebenyuk,
JSC "Roszheldorproject", BIM specialist (infrastructure)
mzjensen
I'm assuming that you are using the "Guard Rail Straight" model that comes with InfraWorks. That 3D model is 3 meters long, so if the length of your imported polygon/line is not divisible by 3, then it will not line up. It is not going to trim the ends and corners; it will only place an object at discrete intervals. If you use a Barrier style instead of a 3D Model, then you have more control.
Zachri Jensen, PE   |
andrewofabley
I've solved this one before - I exported the model and resized it, before reimporting it as a style, or alternatively divided my line section up neatly into 3m sections. One could also dynamically scale the x dimension of the model based on the length difference between the vertices expressed as an attribute.
AEC Collection / Safe FME / ESRI ArcGIS / Unreal Engine
Digital Engineering Lead, Compulsive Problem Solver.
Riyaz.Hussain
Thanks Dear - All is well with barriers and a style with it.
