I try to import network drainage in C3D from InfraWorks 360 .
I have a systematic C3D crash when I clic on the second "Pipe Networks" entry in the "Configure InfraWorks 360 - Civil 3D Exchange Settings" panel.
I don't undrestand the difference between the 2 entries with the same name "Pipe Networks".
Please see the picture attached.
Thanks for any help.
Vincent
Vincent
Solved by MattAndersonPE. Go to Solution.
Vincent -
Have you applied the 2016 French Drainage Hotfix?
Vincent -
Hello Matthew,
It works !
Thank you. I didn't know this Hotfix.
Vincent
Hello Matthew,
It works !
Vincent
