Import from 3dsmax to Infraworks
ashokkr.bro
ashokkr.bro
Hi,   I am new to 3dsmax. I am trying to place vehicle as object on road and try to import in Infraworks.   When I put the Vehicle in 3dsmax  the size of vehicle is so small that it is invisible.   On zooming I see the vehicle. But when I import it in Infraworks due to small size I can see the vehicle.   Pls help me.
Todd_Rogers
When you bring into InfraWorks, it's in meters. So, in InfraWorks config dialog box, make sure you put 3.2808 in the X,Y, and Z for scale.
Todd Rogers
Civil Administration
ashokkr.bro
Hi
Eve the size of car is too small in 3dsmax . Not helped if I put 3.2808.
Regards
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @ashokkr.bro ,
sounds like a default unit setting issue in 3ds Max.
Maybe this helps?
Karsten.
Karsten Saenger
ashokkr.bro
hi,
I am getting the warning message while exporting the animation as DAE . Pls help me.
I am new to this and in the learning process.
Screen shot attached .
Regards
