Importing 3D Models
Importing 3D Models
VincentSheehan
Advisor Advisor
Importing 3D Models
VincentSheehan
I have a question about importing 3D models. I’ve attached two images of what is going on. When I import a model, it looks good during the Interactive Placing but some faces are transparent after I place it. I know 3D faces can face the upside down and I have flipped them in 3DS Max but with no luck. The model was originally created in SketchUp. I’ve tried exporting to different file formats. FBX, DWG, DAE, OBJ and so on. I have never had this issue so any ideas? I'm using version 2019.2.12.0.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Todd_Rogers
Use collada (.dae). However, when you export it from sketchup, it creates a folder with your materials, then puts the collada file separately. Move the collada file into the folder with the materials.
Todd Rogers
Civil Administration at Walter P Moore
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @VincentSheehan ,
in addition to what @Todd_Rogers says, double check if "Show Backfaces" is checked in your 3D Graphics Application Options.
Karsten.
Karsten Saenger
