InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Image Mirrored
3 REPLIES 3
bmason8ZRTS
376 Views, 3 Replies
Image Mirrored
I am starting to work deeper into learning Infraworks and having a strange issue creating a material for a facade on a building. The image / text appears to be mirrored; almost like I am looking through a window from behind it. Is there a way to rotate it?
Any thoughts?
3 REPLIES 3
Any luck here? Same issue for me
How did you generate the buildings? If the building were modeled in another program, it is more than likely due to the face of the wall needs to be flipped. 3D faces have a front and back.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Morning
That would make sense - I downloaded it from the Sketchup library.
Thanks for the response.
Rail Community
