I am starting to work deeper into learning Infraworks and having a strange issue creating a material for a facade on a building. The image / text appears to be mirrored; almost like I am looking through a window from behind it. Is there a way to rotate it?
Any thoughts?
Solved by VincentSheehan. Go to Solution.
How did you generate the buildings? If the building were modeled in another program, it is more than likely due to the face of the wall needs to be flipped. 3D faces have a front and back.
Morning
That would make sense - I downloaded it from the Sketchup library.
Thanks for the response.
