InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Export roads without ground surface as FBX
1 REPLY 1
419 Views, 1 Reply
Is it possible to export roads as FBX separately from the ground surface? There doesn't seem to be a way to separate them in the "Export 3D Model" export settings: I can only export the roads along with the ground surface.
In "Surface Layers," hiding the ground surface hides the roads as well.
Tags (3)
1 REPLY 1
Karsten.Saenger
Hi @Anonymous ,
the planning roads don't have their own profile (=elevation) and they need a terrain to be draped on.
If yo switch off the terrain, the roads disappear as well.
Maybe there is a workaround with a round trip via Civil 3D.
Load the model into Civil 3D, you will see an existing ground surface and a road surface. Export the road surface as LandXML and import that LandXML to InfraWorks. Now the roads have a drape terrain and you can switch off the existing ground.
Karsten.
Karsten Saenger
Rail Community
