Using the model building, I created my project site. I selected the correct coordinate system to begin. When I try to export to .IMX file for import into Civil3d, I get the message: "The given extent does not intersect the defined boundaries of the model coordinate system." I am using Infraworks 2023. Coordinate system is TX83-SF. I have already deleted and recreated the project in Infraworks.
Is there any way to get this model into Civil3d?
Solved by ToddRogers-WPM. Go to Solution.
Check the box for Entire Model. If that doesn't work, make sure you go to Model Properties and set your coordinate system to TX83-SF to match the export coordinate system.
Thanks for the reply.
I tried "Use Entire Model" first. Then the BBox method. And the coordinate system is set correctly.
Still Same Error:
Check this out...
Thanks for looking into this for me!
Here is a screen capture of the site from Civil 3d. I'm pretty certain that I have the right Coordinate System.
unless TX83-SCF is not the same as TX83-SF...
Which I now believe it isn't!
Thanks @ToddRogers-WPM!
I think that is it.
Ah ha! Good ol' south central foot, instead of south foot. I live in Houston BTW...lol.
