InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Error exporting .IMX
6 REPLIES 6
SteveFong
326 Views, 6 Replies
Using the model building, I created my project site.  I selected the correct coordinate system to begin.  When I try to export to .IMX file for import into Civil3d, I get the message: "The given extent does not intersect the defined boundaries of the model coordinate system."  I am using Infraworks 2023.  Coordinate system is TX83-SF.  I have already deleted and recreated the project in Infraworks.
Is there any way to get this model into Civil3d?
6 REPLIES 6
ToddRogers-WPM
in reply to: SteveFong
Check the box for Entire Model. If that doesn't work, make sure you go to Model Properties and set your coordinate system to TX83-SF to match the export coordinate system.
Todd Rogers
SteveFong
in reply to: ToddRogers-WPM
Thanks for the reply.
I tried "Use Entire Model" first.  Then the BBox method.   And the coordinate system is set correctly.
Still Same Error:
ToddRogers-WPM
SteveFong
@ToddRogers-WPM
Thanks for looking into this for me!
Here is a screen capture of the site from Civil 3d.  I'm pretty certain that I have the right Coordinate System.
SteveFong
unless TX83-SCF is not the same as TX83-SF...
Which I now believe it isn't!
Thanks @ToddRogers-WPM!
I think that is it.
ToddRogers-WPM
Ah ha! Good ol' south central foot, instead of south foot. I live in Houston BTW...lol.
Todd Rogers
Rail Community
