Download Infraworks Sample Models
Message 1 of 21
Hi! In the past, I deleted Infraworks sample models, as Dubai Model or Roads Tutorial (September 2016), for example. Now, I desire to download them.
How can I get them again?
Thank you.
Accepted solutions (3)
Replies (20)
Message 2 of 21
Hi @Anonymous,
it was solved in the past, I think you need to follow the same solution.
http://forums.autodesk.com/t5/infraworks-360-forum/infraworks-sample-models/td-p/4452101
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
Message 3 of 21
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous
it's actually not possible to delete these sample models, only the local copies you have downloaded.
What if you search for "Group" = "Samples" on the InfraWorks start page?
Karsten.
Karsten Saenger
Message 4 of 21
I don´t have Sample option y my welcome screen. The language of my Infraworks is spanish.
In the Manage option, the following points appear:
As it can observe, Roads Tutorial (December 2016) and Tutorial (December 2016) appear, but San Francisco model or Dubai models don´t appear.
¿Models can be downloaded in any way? Vía web?
Thank you.
Message 5 of 21
JasonArtley
Type "samples" into the search box to display the sample files.
Message 6 of 21
If I write "Sample" into the search box, Roads Tutorial (December 2016) and Tutorial (December 2016) appear, not other samples.
Message 7 of 21
My friend @Anonymous,
I don't think you can delete the samples in any case. I think it is a matter of the new version.
I have the last one, and, as you can see from the image, I have only two samples.
https://knowledge.autodesk.com/support/infraworks-360/learn-explore/caas/CloudHelp/cloudhelp/ENU/InfraWorks-UserHelp/files/GUID-C4399822-7E90-4996-9408-259E4F9B9297-htm.html
http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-686F84AA-B0AD-4DA6-AE07-2595192E7C6F
No more Dubai 😃
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Message 8 of 21
Honestly, I'm not sure I deleted any files according your answer, because I installed the program since a long time and now I want to use it.
Respect to the sample files, I searched and two samples appeared in the window: similar your picture.
Thus, the ancient tutorials are no longer useful? Thanks.
Message 9 of 21
Karsten.Saenger
Autodesk Support
Autodesk Support
Hello @Anonymous
I have checked my InfraWorks and can confirm that the Dubai Sample is no longer available.
Unfortunately I don't have a local copy that I can share with you. Maybe someone else still has it?
You can also check the InfraWorks Gallery for Ideas what can be done with the program. Maybe someone is willing to share his project from there as well, if you ask.
https://gallery.autodesk.com/civilinfrastructure
Karsten
Karsten Saenger
Message 10 of 21
Carrillof
Can you pass me your email? And I can share them for you to download
If I can help you please click on the kudo button
Message 11 of 21
Thank you very much Carrillof, but I don't need these models. The problem was that I didn't know why the models were not in my computer. I hope that Infraworks add new models and new tutorials coming soon.
Message 12 of 21
Carrillof
OK, THERE IS NO PROBLEM, COINCIDED THAT THERE MUST BE MORE MODELS,
SALUDOS DESDE MEXICO
Message 13 of 21
elliott.rosenfeld
I checked with our product team and we will be reposting the Dubai and Moscow sample models to the Demo/Samples group for users of 2017.3 to consume. You can most likely expect to see them within the next week, if not the next few days.
Principal Specialist, Infrastructure
Message 14 of 21
Excellent Elliot! Thank you for your management.
Message 15 of 21
Thank you for all, Carrillof.
Saludos desde España.
Message 16 of 21
Carrillof
de nada, y seguimos en contacto @Anonymous
Message 17 of 21
elliott.rosenfeld
No problem, happy to help.
Dubai Marina Palm (December 2016) should now be available to users. We are working to make the Moscow model available as well, if possible.
Best,
Elliott
Message 18 of 21
sburns
Can we please get a way to delete these?!??!
I wish you hadn't added them back and maybe just made them available for download to those that wanted them.
It's super annoying that they can't be deleted.
Message 19 of 21
Thank you elliot.rosenfeld! Dubai Marina Palm is now available!
Message 20 of 21
elliott.rosenfeld
So currently they're available in the cloud. I believe you can remove them from your instance by manually deleting the model folder, although you would have to test this out as I am not certain, and cannot delete my instance personally due to a need to support it. Give this a try:
1) Go to:
C:\Users\%username%\Documents\Autodesk InfraWorks Models\Autodesk 360\
2) Delete the model folder. I believe the folder ID is :183225
Let me know how that works.
Elliott
