Creating and using a SHP file to create a Model Builder project extents
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In Civil 3D, create a [closed] Polyline that defines the boundary you would like to use in Model Builder.
Note: The shape can be as simple or complex as your project dictates.
Use MAPEXPORT, select a location and name for the SHP file.
From the Selection Tab> Polygon> Select manually> use the pick box to select your closed polygon.
From the Options Tab> Other> Treat closed polylines as polygons
NOTE: At the bottom you will see if the object[s] selected were filtered out of your selection. If so, you may need to recreate or reselect your objects.
In InfraWorks, open the Model Builder, and use the right-most import option: Import a polygon to select an AOI [area of interest]. Choosed your newly created SHP file:
Willy Campbell
