InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
coverage boundary thickness
2 REPLIES 2
andres.urrutiaBPVY6
348 Views, 2 Replies
Hi. I have imported a couple of shx polygons in order to set as a hole coverage. the problem is when I set the coverage, this area shows a huge thickness around it. does someone know how to modify the thickness?
2 REPLIES 2
Hi, @andres.urrutiaBPVY6!
Yes, press ALT+6 to open the Style Palette, in the Coverage tab, create or edit an existing style. Double-click a style and here you can change the outline width value.
Have a good one!
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
great!! thank you!
Rail Community
