We used to be able to copy Points of Interest from one proposal to another. Has this changed in the latest version, or am I missing a setting?
Thanks.
Solved by JasonArtley. Go to Solution.
Are you referring to the old "Paste to Original Coordinates" right click option? That option did disappear in the latest version, but the keyboard command still works. Find the POI in the proposal you wish to copy from, and copy (CTRL+C) the item. Change proposals and paste to original coordinates (SHIFT+CTRL+V).
This works for POIs in 2017.3
