Hi there,
I'm struggling big time to create a custom traffic sign and then import it into Infraworks. This is my workflow:
I know jump into Infraworks, open the model and select the data sources/ 3D Model. I configure the object and first of all, for some reason I have to scale it up 100 times, otherwise it's tiny (Why!?). Infraworks is set in metric system in meters. I set type to City Furniture and select Interactive Placing, and all I get it's this.
I tried several things like not embedding the materials. I created a brand new sign even using another shape and picture. Same result.
Does anybody come up with this issue? Any help would be highly appreciated.
Cheers
Javier
@Anonymous, you say your working in meters both in Civil 3D and InfraWorks but once imported in InfraWorks you have a scale problem of 100. What Coordinate system did you set in C3D and InfraWorks (DB and UCS)?
It's my guess this is initially causing your problem because I don't have any problems ussing your exact workflow.
