InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Can Not Delete Object
5 REPLIES 5
1395 Views, 5 Replies
Hi..
I import metro track from shapefile and already load in the model. But i need to delete that because some update. I already delete from data source those shapefile but it still appear in model. I already make sure it's not locked in the layer. I also tried delete manually (right click object and delete) but it also not work. When i select that and check the properties its said no selection.
object selected but no properties shown.JPGIt's weird. I also tried to move the metro track but it cant move. It's stack there. I just need to remove that object so i can import or draw the new one.
I already make duplicate model and tried delete several time, it's not works as well. Is anyone ever have the same issue?
Nrdamayanti
5 REPLIES 5
elliott.rosenfeld
Hi NR,
Did you ever resolve this issue? Sorry for the late answer, not sure if this is still relevant for you..
I think this could be resolved by choosing Delete Features from the right click context menu and then choose Refresh. After that, you can Remove the Data Source.
Principal Specialist, Infrastructure
tony1978
Is this model connected to the cloud? If so, try going into the Settings & Utilities and select the Disconnect Model. Then select the Regenerate feature also. Then try deleting the feature.
Try changing the style then deleting.
 Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
jmayo-EE
in reply to: tony1978
"Try changing the style then deleting. "
Thx Tony that was the trick.
John Mayo
Kristian.LarsenM6CEN
Trying to remove/delete a simple rectangle featureclass imported from an arcgis database.
Infraworks 2021 says "deleting" for 1 hour, then uses 90 gb of memory. 90 GB!!!
What is going on?
Hi @Kristian.LarsenM6CEN ,
I'm wondering if there is any error listed in the InfraWorks log file (%appdata%\Autodesk\Autodesk InfraWorks\logs).
My first guess is that it sounds like a model corruption.
Where is you model located - local drive or cloud drive?
Karsten.
Karsten Saenger
Rail Community
