Batch import 3d building
Message 1 of 11
I am new to Infraworks and to scripting.
I found this very useful process on how to batch import 3d building into Infraworks
https://knowledge.autodesk.com/support/infraworks-360/learn-explore/caas/simplecontent/content/aiw36...
I am trying to modify the javascript to import the models not to the base BUILDINGS class but to our custom class 3DBUILDINGS, but keep getting the following error message
ERROR: 3d model import for 3DBUILDINGS failed: /output/VANC0001/VANC0001.dae
Would very much appreciate any help on solving this problem.
Olga
Replies (10)
Message 2 of 11
Matt__W
Without seeing the code and based solely on the error message, it would appear that the code isn't being passing the entire path of the file.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 3 of 11
Here is the script
instead of "BUILDINGS" base class, i would like to use "3DBUILDINGS" - the custom class
Olga
var listing = "Y:/output/listing.txt"
var cs = "UTM83-10";
var db = app.ActiveModelDb;
var Import3dModel = function (filePath, targetClassName, origin, scale, rotation, name) {
if (!file.FileExists(filePath)) {
print("ERROR: 3d model not found: " + filePath);
return false;
var providers = app.GetDataProviders(".dae");
var success = true;
for (p in providers) {
var configs = providers[p].FileConnect(app.ActiveModel, filePath);
for (c in configs) {
var cfg = configs[c];
cfg.Name = name;
cfg.TargetClassName = targetClassName;
cfg.SourceCoordSys = "UTM83-10";
cfg.PosCoordSys = cs;
cfg.AnchorType = adsk.Enums.LocalOrigin;
cfg.Position = origin;
cfg.Scaling = scale;
cfg.Rotation = rotation;
cfg.Is3D = false;
var result = cfg.Import();
if (result != null) {
success &= true;
} else {
print("ERROR: 3d model import for " + targetClassName + " failed: " + filePath);
success &= false;
app.Regenerate();
return success;
//Example on how to import multiple files
var importCollada = function () {
if (!file.FileExists(listing)) {
print("ERROR: Listing not found: " + listing);
return;
var dirs = file.ReadFile(listing);
var dirsa = dirs.replace(/\\/g, "/").split(/\n/);
for (var i = 0; i < dirsa.length; i++)
try {
var dir = dirsa[i].replace(/^\s+|\s+$/g, '');
var kml = dir + "/doc.kml";
var coords = file.ReadFile(kml);
var kmlImport = app.readXml(coords);
// If there is no Folder object, then go to Document object
if(kmlImport.kml.Folder == undefined || kmlImport.kml.Folder == null) {
var model = kmlImport.kml.Document.Placemark.Model;
} else {
var model = kmlImport.kml.Folder.Placemark.Model;
//Geo-location/Origin
var origin = new adsk.Vec3d(model.Location.longitude, model.Location.latitude, model.Location.altitude);
// Scale, if the scale is not set, then assume it is 1
if(model.Scale == undefined || model.Scale == null) {
var scale = new adsk.Vec3d(1,1,1);
} else {
var scale = new adsk.Vec3d(model.Scale.x, model.Scale.y, model.Scale.z);
// Rotation, if the rotation is not set, then there is no rotation applied.
if( model.Orientation == undefined || model.Orientation == null) {
var rotation = new adsk.Vec3d(0, 0, 0);
} else {
var rotation = new adsk.Vec3d(model.Orientation.tilt, model.Orientation.roll, model.Orientation.heading);
var name = dir.split("/");
Import3dModel(dir + "/" + model.Link.href, "BUILDINGS", origin, scale, rotation, name[name.length-1]);
} catch (err) {
print(err+ ": " + dir);
continue;
importCollada();
Message 4 of 11
Matt__W
Can you post the first few lines of this file? (Y:/output/listing.txt)
I'm assuming it's a comma delimited file? If so, the first line should be the "column" headers and the subsequent lines will represent each building.
Thanks.
Matt Wunch
Twitter | LinkedIn
Message 5 of 11
Thank you Matt for looking into this
Here are the lines
Y:\GIS\Data\NEFC\VANC0290
Y:\GIS\Data\NEFC\VANC0291
Y:\GIS\Data\NEFC\VANC0292
Each directory has a DAE file (containing geometry), KML file (containing the coordinate of the insertion point) and texture files.
Olga
Message 6 of 11
Below is the instruction from the original site where i got the scripts
The workflow uses a Javascript and bat script. You need both scripts for correctly importing a number of 3D models. 3D Warehouse models can be downloaded in several formats including KMZ. The KMZ format is actually a ZIP file containing a KML file, Collada DAE model and textures in a separate folder. You can simply use a RMB (Right-Mouse-Button) on the KMZ file and choose extract. In some occasions it helps to have a SketchUp (Pro) license because after the RMB extraction no KML file is generated. When you use SketchUp to export the KMZ file then after RMB extract there will always be a KML file generated. You need the KML file because it holds the geographic position and rotation of the 3D model.
You can download the JS and bat script here. Then follow the next steps:
  1. Extract your KMZ models (if you downloaded them from 3D Warehouse) to folders holding a KML model and subfolder with the Collada DAE and textures. This is very simple by using your RMB on the KMZ file and choose Extract here. It's actually just a zip file.
  2. Then put your extracted models and folders in a separate folder preferably high in the root of the HD.
  3. Then copy the batscript in there and run it. This will create the listing.txt file holding all the KML model folders
  4. Then copy the JS also in and adjust that script using a script editor like Notepad++. The only thing you need to adjust is the first line mapping folder to your drive and folder: var listing ="D:/Temp/listing.txt"
  5. Then copy the whole script by CTRL-A and CTRL-C and paste it into the AIW360 ScriptEditor or load the script from there
  6. Run the script
Now AIW360 will start to import the 3D models one by one and place the Data Sources in the Buildings Model Category.
Message 7 of 11
Matt__W
Just out of curiosity, what does your MODEL EXPLORER look like? When I try to create a custom class I get this.
Matt Wunch
Twitter | LinkedIn
Message 8 of 11
Hi Matt -
we modified the im.schema.json with the following lines
"name": "3DBUILDINGS",
"base": "BUILDINGS",
"Attributes": [
"displayName": "3D Buildings",
"category": "Buildings"
and the result in the Infraworks
Olga
Message 9 of 11
Matt__W
Okay...
Instead of using 3DBUILDINGS in the Javascript code, try passing "USER_3DBUILDINGS".
Matt Wunch
Twitter | LinkedIn
Message 10 of 11
Hi Matt -
it worked !!!!
Can't thank you enough for helping with me this
Olga
Message 11 of 11
Matt__W
I'm glad we got it working for you!
Matt Wunch
Twitter | LinkedIn
