InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Assembly exported from Infraworks to Civil 3D
1 REPLY 1
Ben.Quintero
209 Views, 1 Reply
Hi all,
I am having an issue with the corridor assembly that is brought into Civil 3D through "Import IMX" from Infraworks. For some reason where the curb and gutter and greenspace meet, they are overlapping instead of connecting at the end. Is there a way to fix this within Infraworks so that it wouldn't have to be edited in civil 3D?
Any help with this issue would be greatly appreciated.
Attached is a photo of the Infraworks Cross Section and the Civil 3D Assembly
1 REPLY 1
Matheus-Lima
in reply to: Ben.Quintero
Hello, Ben!
Did you try to import in Civil 3D the sqlite directly instead of the IMX? Besides that, I would just edit it in Civil 3D moving the subassemblies, it's simple to solve. The interoperability between Civil 3D and IW is in continuous development.
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Rail Community
