Hi @htariq.bece17nice, this video may help you out. The speakers of this AU class created parametric models in Inventor and imported them into InfraWorks. There is this element, a cornice, that reminds a little bit the shear key your're after.
AU Class: The New Workflow for Bridge Design with InfraWorks, Inventor, Civil 3D, and Revit by VINCENT FREDON and STEPHANE BALMAIN.
Check at 27:21 of this video: https://www.autodesk.com/autodesk-university/class/New-Workflow-Bridge-Design-InfraWorks-Inventor-Ci...
Hope it helps,
[PT-BR] Se essa postagem foi útil para você, clique em
Curtir! Se a resposta resolveu o seu problema, clique em
Aceitar Solução. [EN-US] If it was helpful to you, click on
Like! If the answer solved your problem, click on
Accept Solution. Matheus Lima Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager |
Instagram @bim_infra |
LinkedIn
