Pattern to Sketch Points
Would be neat to create a sketch with (say 34) points spaced randomly based off my design where I need to pattern an M5 nut, vs path pattern, do sketch point pattern.
2 Comments
tysonbunker
It would be nice if you could easily do hole (or other) patterns from sketch points. For example, you sketch a field of points, reference the first hole/feature on a point, select a sketch points pattern in the menu then select the feature and sketch to generate the pattern.
Tyson
Tags (5)
TrippyLighting
These ideas are similar.
