Show only
Search instead for
Submitted byAnonymouson07-29-201612:29 PM
Status:
Gathering Support
Pattern to Sketch Points
Would be neat to create a sketch with (say 34) points spaced randomly based off my design where I need to pattern an M5 nut, vs path pattern, do sketch point pattern.
It would be nice if you could easily do hole (or other) patterns from sketch points. For example, you sketch a field of points, reference the first hole/feature on a point, select a sketch points pattern in the menu then select the feature and sketch to generate the pattern.
