Reusable and sketch based patterns
The ability to use the same pattern for several things could really speed up things, for example assembly of bolts into a bolt pattern.
Right now one first has to create a hole pattern and then a separate bolt pattern. Fairly easy to do with a circular pattern, but it becomes tedious when trying that with a hole pattern as created with te hole tool.
It would be nice to re-use an already existing pattern even for a circular bolt pattern even if you just want to change the number of bolts.
For a hole patetrn, when adding new locations another screw has to be copy-pasted adn then assembled instaed of hving an instance appear based on a pattern. Real situations where a screw joins components that same pattern currently has to be generated three times. Once for the through holes, onece for the component the screws are threaded into and once for the screws.
Here is a screencast that hopefully helps explaining it.
Some of what I have explained above is called a Sketch based pattern in SW and can be really powerful.
6 Comments
kb9ydn
Yes, a sketch based pattern and a feature driven component pattern.
C|
promm
TrippyLighting,
Thank you for your idea - this is getting moved to future consideration.  The plan is to have the ability to reuse patterns in features like the future fastener wizard.  The are other projects that this depends on that are in the works, once completed it will allow us to start developments on this.
Cheers,
Mike Prom
TrippyLighting
Cool. Thanks!
This would be hugely helpful. Any progress on this in the last 3 years?
marc.wildURG6N
That would be really really helpful!
All other CADs use this way of work since many years...
steven2605
Community Visitor
I am a hobbyist and new to cad.  I choose fusion 360 because by description best suited my needs. Learning the application has been quite challenge do to the support training assumes previously acquired experience. Some training videos on the use of very basic tools would be very beneficial and the addition of template based features would be even better.
