In my professional engineering life Drawing is the most important thing when I working.
As now Fusion 360 offer really small amount of Drawing option to me and I suggest that it need to be improve.
Here are my suggestions.
1. Atleast make it so after I convert file to dwg I can use another CAD to edit my drawing. Right now when I export it to another CAD the drawing just appear to have no model line in it. Make it completely unable to edit and in some case can not even open it. (If this was my fault I will be happy if you can point the solution for me. The CAD I use is Draftsight and LibreCAD)
2. Add function so we can manually add line or edit line in each view
3. Let us edit and/or create our own Drawing layout. It is really important for Engineering work.
4. Lacking of welding symblom is really a big no for me.
5. Adding more customize for text and line. (Line size, shape, color etc)
6. More option for center line and center mark. (Orientation basically)
Basically all engineering annotation and advance drawing.
(In true if you dont have enough man power for this just allow us to manually edit or
just as I write above make dwg file work on other CAD program and I will be happy)
Have high hope for this program and appreciate the work you guy done so far.
Just this drawing function that really dissatisfy me.
