It would be great to have the ability to set up a custom numbering scheme for Components in Fusion.
I wish it could be something like what has been availbale in Autodesk Vault for some time already: http://help.autodesk.com/view/VAULT/2016/ENU/?guid=GUID-F5356B61-194B-45BF-8B92-31C299A37206
Imagine after defining the format for the numbering(s) you want to use, you could use a auto-generated number from the scheme to apply to design files, as well as components within a design. When saving a new design file, or when creating a new component inside a design file, you could get a message box where you could select which numbering scheme to apply, and it would create a new number from it (the next available one). Similar, you could right-click on a Component, select rename, and get the same message box again, for applying a new number to let's say an imported component.
The reason for wanting this is, beacuse at some point further down the line, after exporting your BOM for further use in PLM and ERP-systems, I would want to have part numbers (file names) at a unified format, without risk of typing errors or duplicate numbers.
I hope the above makes sense. This is what I have used for many years with Inventor and Vault, and I believe it is absolutely necessary to have a feature like this in Fusion, atleast for proffesional CAD users.
