Show only
Search instead for
Cheap but useful : each time we create a new body with a command > ask for a name pre-filled with "body xx". It saves time when you want to keep things organized.
Either as suggested by the OP, or immediately highlight in the browser for renaming (hit RETURN to accept default name if no change is needed). Would extend this to sketches, really anything that gets listed in the browser. Would also add a toggle in preferences to enable/disable this functionality.
If i understant correctly the naming is just available for the extrusion right?
If so we need this to be generalised each time we can create a new body : on all "create" objects, combine (when it creates a new body), revolve, sweep, loft...
