Extrude with body name definition
jan_priban
Alumni Alumni
Message 1 of 1
jan_priban
based on the post  Body Name I made simple Add-In trying to help, fill user's wish. Add-In does just extrude (creating new body under the active component) + renaming. So it is simple dialog where you can define profile (a sketch profile, planar face), extrude distance + body name.
Set of images shows how to add existing Add-In. So just download the attached ZIP file, unpack and from the Fusion File menu add Add-In = click "+" sign and browse to location where you unzip CustomExtrude.zip.
If you will find it usefull, I can make similar for Revolve.
Regards
Jan
Replies (0)
