View generated g-code during simulation
ddodtXA7DR
Message 1 of 12
ddodtXA7DR
Was wondering if there is a way to view the generated g-code, line by line, while a machining simulation runs.
Replies (11)
Message 2 of 12
kacper.suchomski
Hi
Open cnc file in HSM Editor software.
Kacper Suchomski
Message 3 of 12
ddodtXA7DR
I should have been more clear.  What I was hoping for was a window with the code, line for line, while the simulation runs.
Message 4 of 12
FTKnur
Perhaps you can try this:
in english it should be named "show toolpath"?
you can click on code to "simulate" line per line.
Message 5 of 12
ddodtXA7DR
Thank you, looks like this is close as close as I am going to get to what I was looking for.  It would be nice to see the program run alongside the tool without having to select each line of code.
Message 6 of 12
seth.madore
This is available in Fusion, if you're interested 🙂
Seth Madore
Message 7 of 12
magnus.brandtPB4X8
Yes but this whould be nice to have inside simulation whid stock and everything.
Message 8 of 12
seth.madore
It is available, if you're a member of the Insider program. Membership is free, but it does involve an application process. You can apply here: https://feedback.autodesk.com/key/Fusion360Insider
Seth Madore
Message 9 of 12
magnus.brandtPB4X8
Hi
Yes i am a member of the inside program , just havent had the time to test the new version for some time now.
do you know then this function will hit  public version?
Message 10 of 12
seth.madore
I do not. However, you don't need to use the Insider build alone to see that feature. This feature should be available to you in the Production (once you've signed up for Insider).
Seth Madore
Message 11 of 12
magnus.brandtPB4X8
Hi
Well i dont se that,
I can use Toolpath Data and simulate but there is no stock option there
 And in simulation there i got stock and everything but i only se the position
 I whould like to see the toolpath data window in simulation that whould be perfect.
Message 12 of 12
aaron.fahl
What do you mean "Production"?
I activated my Insider acct. yesterday.
Im in the Manufacture workspace.  I have the manufacturing extension if that helps.
