HSM Support Forum
View generated g-code during simulation
10 REPLIES 10
Message 1 of 11
ddodtXA7DR
1064 Views, 10 Replies
Was wondering if there is a way to view the generated g-code, line by line, while a machining simulation runs.
10 REPLIES 10
Message 2 of 11
Hi
Open cnc file in HSM Editor software.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 3 of 11
ddodtXA7DR
in reply to: ddodtXA7DR
I should have been more clear.  What I was hoping for was a window with the code, line for line, while the simulation runs.
Message 4 of 11
FTKnur
Perhaps you can try this:
in english it should be named "show toolpath"?
you can click on code to "simulate" line per line.
Message 5 of 11
ddodtXA7DR
Thank you, looks like this is close as close as I am going to get to what I was looking for.  It would be nice to see the program run alongside the tool without having to select each line of code.
Message 6 of 11
seth.madore
This is available in Fusion, if you're interested 🙂
Seth Madore
Message 7 of 11
Yes but this whould be nice to have inside simulation whid stock and everything.
Message 8 of 11
It is available, if you're a member of the Insider program. Membership is free, but it does involve an application process. You can apply here: https://feedback.autodesk.com/key/Fusion360Insider
Seth Madore
Message 9 of 11
Hi
Yes i am a member of the inside program , just havent had the time to test the new version for some time now.
do you know then this function will hit  public version?
Message 10 of 11
I do not. However, you don't need to use the Insider build alone to see that feature. This feature should be available to you in the Production (once you've signed up for Insider).
Seth Madore
Message 11 of 11
Hi
Well i dont se that,
I can use Toolpath Data and simulate but there is no stock option there
 And in simulation there i got stock and everything but i only se the position
 I whould like to see the toolpath data window in simulation that whould be perfect.
