Was wondering if there is a way to view the generated g-code, line by line, while a machining simulation runs.
Solved by FTKnur. Go to Solution.
Hi
Open cnc file in HSM Editor software.
Kacper Suchomski
I should have been more clear. What I was hoping for was a window with the code, line for line, while the simulation runs.
Perhaps you can try this:
in english it should be named "show toolpath"?
you can click on code to "simulate" line per line.
Thank you, looks like this is close as close as I am going to get to what I was looking for. It would be nice to see the program run alongside the tool without having to select each line of code.
This is available in Fusion, if you're interested 🙂
Yes but this whould be nice to have inside simulation whid stock and everything.
It is available, if you're a member of the Insider program. Membership is free, but it does involve an application process. You can apply here: https://feedback.autodesk.com/key/Fusion360Insider
Hi
Yes i am a member of the inside program , just havent had the time to test the new version for some time now.
do you know then this function will hit public version?
I do not. However, you don't need to use the Insider build alone to see that feature. This feature should be available to you in the Production (once you've signed up for Insider).
Hi
Well i dont se that,
I can use Toolpath Data and simulate but there is no stock option there
And in simulation there i got stock and everything but i only se the position
I whould like to see the toolpath data window in simulation that whould be perfect.
