HSM Support Forum
Toolpath not generating on cylindrical faces
7 REPLIES 7
Message 1 of 8
535 Views, 7 Replies
I am currently trying to generate a boring toolpath on a cylindrical face without luck.
The strange thing about this is that the exact same model use to generate the path just fine, but it seems other strategies are also failing on the same face, yielding and error:
Warning: Selected face not in job model selection!
If I modify the part to have a taper, then the path generates.
I am using version 2019
Tags (3)
7 REPLIES 7
Message 2 of 8
Laurens-3DTechDraw
For some reason your model isn't(or no longer) selected in the setup.
Pretty sure if you select the model correctly in the setup it will work again.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 3 of 8
in reply to: Laurens-3DTechDraw
I have tried that, it does not work.
Please also note:
1. All the other toolpaths generate just fine
2. When I modify the cylindrical surface to be conical, it works, but stops working when changed back to a cylinder
Message 4 of 8
Laurens-3DTechDraw
That sounds weird.
Any chance you can attach the files here?
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 5 of 8
Attached herewith.
As stated before, the CAM use to export just fine.
Message 6 of 8
Laurens-3DTechDraw
Can't get it to work properly either.
Lets ping @seth.madore
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 7 of 8
Unfortunately, this is a known bug. Something broke in the move from 2019 to 2020 and the team is working on developing a fix for it. As you discovered, even the slightest taper to the part will allow for toolpath creation.
This is logged as CAM-14953. No ETA as of yet when it will be available
Seth Madore
Message 8 of 8
in reply to: seth.madore
Thank you for the update.
