Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
HSM Support Forum
Stock model selection on second setup causes program crash
8 REPLIES 8
Message 1 of 9
572 Views, 8 Replies
Hey fellow Autodesk CAM users! Not sure if this has been posted already so forgive me if it is.
I ran into an issue today where I create a second CAM setup in an Inventor assembly file and when I choose to select a model as the stock, then click the solid body from the tree, the program crashes.
8 REPLIES 8
Message 2 of 9
need to know your inventor and the HSM software versions.
Message 3 of 9
Inventor build 227 and HSM 5.3.1.188
Message 4 of 9
jeff.pek
Hi -
You didn't post the stock1.ipt component. Is that resolved for you? Or is the issue that you're selecting a body from an unresolved component?
Jeff
Message 5 of 9
in reply to: jeff.pek
Whoops, I forgot to attach the file here. Here it is now.
Message 6 of 9
jeff.pek
Hi -
I can reproduce this issue, and we will see if we can figure out how to fix it. Unfortunately I don't have a workaround suggestion at the moment. It's related to the graphics that are being shown for selection, etc., so I think it should be relatively straightforward to fix, once we can figure out what's happening.
Thank you for sharing the model.
Jeff
Message 7 of 9
No problem. I just worked around it by making a new assembly for the second operation and placing the first operation assembly inside it. Thanks for the quick response!
Message 8 of 9
jeff.pek
After some investigation, it turns out that this crash is being triggered by the switch to Modeling view in the Inventor browser after starting the Setup command. Some graphics objects are being deleted out from underneath the addin, resulting in the problem when it tries to access them.
To avoid the problem, you can switch to modeling view before starting the command.
Jeff
Message 9 of 9
Awesome, thank you Jeff!
