Good morning,
I have not been able to download and install correctly my $$ version of inventor pro for weeks now. The install originally was solid until I made some setting changes to it. (one issue was A360 was just opening a blank window) so I tried to fix it and This is when the trouble began. after several attempts to repair I uninstalled Inventor and tried to reinstall. It installs but it isn't pro and locks the screen and has errors or states it need some service pack?. I downloaded what it said to do but states in still needs it? If this was just 1 issue I would post it here. I really messed it up:( I do think it has something to do with license
What would be the quickest simplest way to resolve this? Call in? Screen share?
I'm using Windows7 on a Panasonic tough book 64bit and at work a OptiPlex 9020 Dell with Windows7 64bit this works but I think it is not set up correctly- it locks the screen when opening software too.
Thanks and have a great day!
Karl
It has been a few weeks so I don't remember exactly what errors. Been using Fusion360
96911/ 969H1 keys 2015 2016 2017 all tried
I paid for Pro but doesn't give me the options in the download/management page.
I will try my lap top later again to refresh my memory of what exactly is going on when installing.
Hi Karl,
Your product key for Inventor HSM should be [969L1] (be sure to use the lower case "L")
Please try again, by entering your s/n and the product key above.
Please let us know if this does not work and I will call you directly to assist.
It would not be an L, but an I (eye). That would be for the 2017 version.
As I mentioned in a PM, 969I1 is the Inventor HSM product key -- not Pro.
Jeff
Thank you Jeff, for clarifying the correct product key!
Karl, Please let us know if you are still having problems with activation after entering the correct product key per Jeff's reply above.
Hi Wayne,
I'm home giving this a try. Fingers crossed:) thanks for the response and PS that last webinar you did was AWESOME!
@ Jeff thanks again
I'll update you guys as soon as I get it installed either tonight or early AM.
OK
I think I'm going to try reading some install tips. Not sure why it's greyd out?
The Pro version is greyed out?
Wayne,
I did not have any luck on the install of Pro. When I try to install it a window pop up states This file is temp unavailable please try again later.
Not sure what to do know?
Hi Karl -
Which install option are you using? Install Now? Download Manager?
Can you show a screenshot of the error?
Jeff
Question: Do you already have Inventor installed? That is a prerequisite here.
I don't know that would explain what you're seeing, but that would be something that you need, regardless.
I wonder if you'd have better luck installing, first Inventor, then Inventor HSM, from the Account Portal (manage.autodesk.com), rather than from the Desktop App.
Jeff
Hi Jeff,
I used the portal first to install software, The desk top app was last. It popped up the window after a reboot this morning. Sorry I only have been using CAD/Cam for about 6 months so I am very green. thanks for your help.
Here is what is installed
OK, thanks. So it looks like a couple different versions (2015, 2016) of Inventor are installed. That should be OK.
I would focus on Inventor HSM 2017, since it's compatible with those older versions of Inventor.
When you download & install Inventor HSM, which option are you choosing (Download Now vs. Install Now)?
When you install, make sure you're leaving the browser window open that you initiated the install from (for Install Now).
If there are errors, there should be some log files written to %temp% -- would be good to see any of those.
Jeff
Hi -
I'm still not clear on exactly what you're doing or seeing.
Are you trying to install Inventor? Or Inventor HSM?
Can you show me the screen that shows the problem?
I'm OK with trying to work through this if you are.
Jeff
OK, so it looks like both Inventor and Inventor HSM are installed.
Remind me what's not working? You have the Premium level license (which is the lower of the 2 paid tiers).
Jeff
I can't find where 2017 is? So I can not open it. I see the file under the Autodesk file when I try to open I get this lost Comm error.
