I'm sorry if this has been answered, but I've dug through the forums and haven't found quite what I'm looking for.
I have a hand full of parts to run, I was hoping to put two in the vise and get two done at once as shown below:
I don't see where to tell Inventor CAM what the right setup is G54 and the left is G55.
I see under the Setup > Post Process tab that there is an option for Multiple WCS offsets. I think this is what I'm looking for, but I can't assign G54, G55... etc to anything specific.
I want it to machine everything with tool 2 on both setups before moving on to tool 3, etc... And I think selecting the Operation Order: Order by tool will accomplish this?
I've seen one forum post saying to use a setup for each tool to make this happen, but with the 'Multiple WCS offsets' checked I think with each setup I'd get greater and greater work offsets instead of going back and forth between G54/G55.
Does anyone have any tips, or links to tutorials for setting up multiple parts?
Also, will the different orientations cause issues?
Solved by Marco.Takx. Go to Solution.
Hi @bkeeneNEC7T,
You have to create 2 setups
First setup set in the post processor tab that is it WCS 1
Create all the toolpaths for that side.
Create a second setup and set on the post processor tab that it is WCS 2
Again create the operations for that setup.
Now you can select Setup1 & Setup2 and Post Process those setups at once.
you also can select within the post processor action to minimize toolchange for a optimal program.
Hope this explanation helps you.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Hi
Have you checked the capabilities of the Pattern tool (in the CAM module, not modeling).
Kacper Suchomski
