Initial Work Offset Posting Twice (Multiple WCS)
Message 1 of 46
Hello there,
When I post multiple WCS over more than one setup at the same time, it will run through all the WCS in the setup in sequence in whatever way I specify (preserve order, order by op.....) and then it will run the first WCS in that setup again, in full preserved order, before moving to the next setup, where it does exactly the same thing.
For example,
Setup1 runs at G54 and G55 (in preserve order to keep it simple).
Setup2 runs at G56 and G57 (again in preserve order).
If I select both setups at the same time and post it out, it runs as follows: G54, G55, G54, G56, G57, G56. I think I had the same issue with the reorder to minimise tool changes box checked too.
If I post the setups individually they post out as expected. The issue exists using the Mazak post I've modified and a test done with the generic Haas too.
Is anyone else experiencing this issue? Any ideas what the problem could be?
Dave
Replies (45)
Message 41 of 46
Yes Keith, I tried every conceivable way of posting the code before I even started this thread. None of them worked!
Message 42 of 46
keith_clausen
Hi Dave,
I will leave this to ADSK then as I don't think there is much I can do to help in this case.
Keith Clausen
Gcode In Motion
SolidWorks 2021
HSMWorks 2022
Fusion360 - Manufacturing Extensions
Message 43 of 46
bob.schultz
Hello Dave,
Sorry if this is a redundant question, but before adding this scenario to the existing ticket I need to know if you have tried both right clicking a setup (after selecting both setups) and selecting "Post Process All ..." and the second method of pressing the "Post Process" button on the CAM menu?
Bob
Bob Schultz
Sr. Post Processor Developer
Message 44 of 46
@bob.schultz wrote:
Hello Dave,
Bob
Bob,
It is I who needs to apologise. Ctrl+left clicking and selecting the setups I need, then right clicking to post, is my usual workflow and it did not work correctly with my old build (I did write the version number down, but it seems to have disappeared. It was a few updates old though).
It seems that with the latest version of HSM installed, the workflow described above does indeed produce the correct, expected output! I could have sworn I tested this method too after I updated, but clearly I was mistaken!
Anyway, thank you both very much for your assistance.
Dave
Message 45 of 46
keith_clausen
Good to hear Dave!
Keith Clausen
Gcode In Motion
SolidWorks 2021
HSMWorks 2022
Message 46 of 46
Yes indeed!
Thanks again Keith.
