Hello there,
When I post multiple WCS over more than one setup at the same time, it will run through all the WCS in the setup in sequence in whatever way I specify (preserve order, order by op.....) and then it will run the first WCS in that setup again, in full preserved order, before moving to the next setup, where it does exactly the same thing.
For example,
Setup1 runs at G54 and G55 (in preserve order to keep it simple).
Setup2 runs at G56 and G57 (again in preserve order).
If I select both setups at the same time and post it out, it runs as follows: G54, G55, G54, G56, G57, G56. I think I had the same issue with the reorder to minimise tool changes box checked too.
If I post the setups individually they post out as expected. The issue exists using the Mazak post I've modified and a test done with the generic Haas too.
Is anyone else experiencing this issue? Any ideas what the problem could be?
Dave
