Cimco Editor not opening after post processing.
kev.oue
kev.oue
Hello all,
I have solidworks 2018 Standard with HSM Express 2019. I have been using it for over a year now really without any issue until the other day I post processed a job and the editor didn't come up as it always has.  So now I have to manually open the editor afterwards if I want to transfer. It still works but is incredibly annoying. Any help would be greatly appreciated.
OS Name Microsoft Windows 10 Home
Version 10.0.17763 Build 17763
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Manufacturer Alienware
System Model Alienware 17 R5
System Type x64-based PC
System SKU 0877
Processor Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz, 2208 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date Alienware 1.7.0, 4/18/2019
SMBIOS Version 3.1
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Alienware
BaseBoard Product Alienware 17 R5
BaseBoard Version A00
Platform Role Mobile
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume3
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 9.43 GB
Total Virtual Memory 47.1 GB
Available Virtual Memory 37.0 GB
Page File Space 31.3 GB
Page File D:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
jeff.pek
I think there's either a preference setting, or maybe an option in the post dialog that controls this. Is it possible that that has changed somehow?
Jeff
kev.oue
I dont ever remember seeing that setting but I will check,  Its very unlikely that its changed as I am the only one that uses the computer and it has been running fine for months without making any changes to HSM config or the templates. I will check.. thanks!
lenny_1962
also have there been any other update to your PC, windows updates new software, new SW SP's????
could mess with it.
have you turned HSMWorks of via add-ins and then turn it back on, I've had to do that once in a while when I've not shut down SW or the PC for a long time...days\weeks
kev.oue
Just an update, I have been unable to find any setting relating to how HSM edit reacts after post processing.
My computer is set to receive automatic updates, but I have not updated Solidworks or HSM. I have Solidworks SP5.  If I cant get this figured out I will try reinstalling when I have time. Thank you guys for your time.
lenny_1962
