Okuma Multus Post Processors
46 Comments
billcainautodesk
@rswartz099
I don't know why it wouldn't work with Trace. If you can post the project in the HSM or Fusion forums I am sure we can look into it.
rswartz099
@billcainautodesk Its the same project as before.
billcainautodesk
@rswartz099
Oh Okay, The Multus post is using TCP as I said. This is still going to rotate the part just like XZC mode would. Just with TCP code in place of XZC. Have you tried that yet?
operator1SX368
Observer
Greetings from the Czech Republic
We are going to buy a Multus B400 W1500, I read that there are a few users here who have a Multus.
The question is, do you know where I could download the model of this stand in .cps types?
Have a nice day
andytpks
I think post processor now is not bad. TD=01XXXX... TD=05XXXX, is a good start. Work in main spindle and subspindle very well.
But if i make one vertical operation and later horizontal operation with the same tool, i have just the rotation of the head. I think is better "recall" TD=05XXXX, i don't know if you know what i mean... maybe i have different tool compensation from vertical to horizontal position, so is better recall the tool. Is possible add this?
(and remember subprogram :D)
I have also little problem with multiturret... is normal?
Thank you!
rswartz099
@andytpks Best solution so far is to manually edit to put the correct position number that you want and take out the G52 BA= line of the code.
Technology Administrators
