Axis swap post proccesor
I'm having a trouble where my spindle could be mounted in +-x, +-y or z axis.
Fusion assumes that the spindle will be mounted in Z axis and whenever I try to change it tends to "rotate" the work rather than being able to swap the spindle. doing some research here I came across other people with the same problem (indexable heads).
My idea is that you set everything as usual in the CAM side and in post have a dropdown menu which asks where is the spindle mounted and then perform an axis swap?
