Combine the default setup sheets in to one.
Title says it all. I like the tool sheet, but it needs the part info on the top like this.
6 Comments
cj.abraham
This feature is already implemented, but kind of hidden. If you use the the post process button and the select the setup sheet post, there will be a property called "showTools" which you can change to "yes" to show the tool table. showtool.PNG
That said, I think it is a good idea to show this table by default and maybe move some things around
AchimN
Here is a preview of the changes to the setup sheet:
- enabled "showTools" by default
- added a seperate column for holder informations
- added handling for turning tools into the tool info
AchimN
Status changed to: Accepted
Greg_Haisley
@AchimN One word Awesome!! Thanks so much. Little things like this make life a little bit easier for all.
I am assuming that the revised setup sheet.cps is going to be here. Just checked it is not uploaded yet.
Thanks again AchimN,
Greg Haisley
Camtool Inc.
AchimN
@Greg_Haisley cool, glad you like it 🙂
Thanks for your feedback and your suggestion for that.
Yes, it should show up soon into the library.
AchimN
