A 5 axis simultaneous tool path made on Fusion 360, post processed without TCP mode, is resulting in a jerky motion of the machine. But at the same time, with TCP mode ON, the tool path is smooth but the controller requires an in-built TCP mode to perform smoothly. And a lot of economic controllers in the market does not have this feature.
I would like to request for the addition of a function to Autodesk Post Processor Class, so that any controller which does not have a TCP mode can be used to run 5-axis simultaneous G-code.
A similar function, as below, could be added or the same can be updated to include an option for using controllers without TCP mode, so that the tool-path will not be jerky.
optimizeMachineAnglesByMachine ( MachineConfiguration machine, Integer tcp )
0: Maintain tool tip position (TCPM). In this function we have only 3 options
- 1: Map tool tip position.
- 2: Map tool tip position for machine axes in table only.
Kindly look into this issue.
Hoping to hear a positive response from your end.
Amit Kumar.
