CAMPROX: cam software post library
Hello all,
We have purchases a Yilmaz CNC which runs off CAMPROX at this point in time it has the worse workflow ever.
as follow inventor export as STEP to CAMxTracts export as .ncx to camQuix which is you programming software than export as .prg to your machine. it would be awesome to go from hsm to the machine.
Machine: https://www.yilmazmachine.com.tr/en/aim-4310-aluminium-profile-processing-center
Software: https://camprox.com/products/camquix/
AUTOCAD PLEASE HELP.
1 Comment
AchimN
Seems that this machine is able to read "standard" G-code as mentioned on their webpage:
- Standard ISO ‘G’ code programming language
So you might want to try either the generic fanuc post or the RS274D post:
https://cam.autodesk.com/hsmposts?p=fanuc
https://cam.autodesk.com/hsmposts?p=rs274
